timing table
timing table
If i were to copy the high octane timing table to the low octane timiming table, would the pcm stil pull timing if it detects knock? Also, is 25.5 degrees of advance high, low, or ok.
Originally Posted by MeentSS02
Sounds okay...as long as you aren't getting any knock, it should be fine.
Originally Posted by Rays C5
Not to high jack the thraed but why is 98s/99 ls1 wot timing higher than 2000 and up??? Mines stock is 29 in the extreme load/rpm range. I know the 98 had a slightly more aggressive cam(bearly) But all else is relatively equal. Wher I see 22/24 the max in the same given area.
