FPSS, fuel pressure gauge, and wet kit all at once???
I got a little ahead of myself over the weekend and ordered a Dynotune wet kit, FPSS, and fuel pressure gauge. I got the pressure gauge today and started hooking it up when I realized that all three hook up to my car's one schraeder valve. I know that people who use a fpss and a wet kit usually hook up a 'Y' or 'T' off the valve, but I've never heard of anyone running all three at once. Do they make three post adaptors? Should I run a "T" into another 'T'? Should I ditch the FPSS and just run the fuel pressure gauge and wet kit of a 'T'? Any help's appreciated.
Originally Posted by GM Muscle
Go back to Dynotune's site and look under gauge adapters. You'll find a -4an manifold with two 1/8" NPT ports. It should work perfectly and look real clean.
Originally Posted by Zeus
so ditch the FPSS, and run the kit and pressure gauge off the adaptor hooked to the schraeder?
No the adapter has an inlet, outlet, and two ports. So you can run your fuel line, FPSS, and gauge sender all of one manifold.
