opinions on this cam 224/232 .590 .585 114
Old 09-21-2005, 10:40 PM
ninobrn99's Avatar
Default opinions on this cam 224/232 .590 .585 114
how well do you think this cam would perform on a full bolt on m6? just some specs i threw together. I pulled my fm-10 114 and want to upgrade, but i want better torque and hp overall. previous numbers less pulley was 378/372
The 3 main cams im looking at are fm13 and 14 and the torquer II also. Im excluding those till I can figure out whats gonna be best for me.
Old 09-22-2005, 01:21 AM
8banger's Avatar
Nino, man, what up? 224/232? Honestly, that wide of a split, especially ground on a 114, sounds like a blower or nitrous cam. I don't know how much it would put out over a 224/224, but I would think it should be higher than the FM10, at least on the HP side. Torque i don't really know. The lift is anything huge either, so who knows. The torquer II is solid. Who makes that 224/232?
Old 09-22-2005, 09:10 AM
ninobrn99's Avatar
no one just some specs im thrwoing around. I know it seems like it would be a good cam for either one and since im gonna spray it may very well be what i need, but you know me..indecisive
Old 09-22-2005, 10:21 AM
8banger's Avatar
YOU indecisive? Look at me...I've had 4 cams so far (TR236, TSP 233/239, G5X2, FM10) and haven't installed any of them because I can't make up my mind. Have you ever heard of the Lingenfelter GT1 cam? It's a 229/242 .639/.631, on a 114. Just found it....looks like it could be fun, though I may have a little too high-flowing of an exhaust setup for it. Call EDC man.
Adam
Old 09-22-2005, 10:36 AM
ninobrn99's Avatar
too much lift!! and the split is insane!! we're in the same boat
Old 09-22-2005, 12:30 PM
Ragtop 99's Avatar
If you are running cats and a stock mufler, the extra exhaust duration is a good idea. If you are starting with a 224/224, maybe you want to add another 2 - 4* on the intake. 226/232 114 +4 or 228/234 115 +4
Old 09-22-2005, 01:00 PM
ninobrn99's Avatar
i had a f10 in there before. 228/228
Old 09-23-2005, 07:03 AM
8banger's Avatar
Not to hijack the thread, but what would you say for LT's, no cats, and Corsa? Something like a 232/240? Maybe even a reverse split?
Quick Reply: opinions on this cam 224/232 .590 .585 114
