View Poll Results: Which one for 475-490RWTQ and 485RWHP
Head/Cam 408CI block
50.00%
Turbo(intercooled)
46.15%
Vortech or ATI
15.38%
Multiple Choice Poll. Voters: 26. You may not vote on this poll
NA or FI?
Old 09-23-2005, 09:32 PM
RedWS601's Avatar
Default NA or FI?
Of course one of these will be installed after a rear end and chassis done up. My final goals are 485rwhp and 490rwtq. Not really looking for low cost but just safe and dependability. Also sound which one sounds the best, lopey cam, blower whine, or blow-off valve?
Thanks positive and negative comments are welcome.
Old 09-23-2005, 10:14 PM
30th t/a's Avatar
do you want to idle like a stocker? or idle like a rocker?
i already had 2 H/C setups and now im going twin turbo, it sounds cool but im already having thoughts thinking "should i have went with a big stroker instead? " NA is way easier to tune and maintane, but its going to be loud. if you just want to go kick *** on the street or track then id get a stroker but if you want to stay quiet with a smooth ride and still be fast as hell....go turbo.
a big cammed ls1 awesome sounds sweet, but when your cruising for 2 hours straight, it gets annoying cause its so loud.
a turbo sounds like a freaking jet when you floored which is badass but at idle their quiet as hell.....actually too quiet IMO. i heard a couple and i could barley tell if they were running.
Old 09-23-2005, 10:27 PM
RedWS601's Avatar
how loud is it actually? I don't know what either sound like but rocker sounds good.
Old 09-23-2005, 10:58 PM
Beast96Z's Avatar
It all really depends on how you want to achieve your goal. I had opted for the smaller motor/big nitrous at first, but then sold that set-up because I didn't feel like getting bottles filled all the time. My next set-up will be a big cube/big cam/big heads stroker motor. This way I can run normal plugs with a max effort tune and never have to worry about small thing throwing the tune off. As for the sound, you can always quieten it down with a good exaust. If yu like the maitenence of a FI set up, then go for it, but for ease and a get in and go, any time, any where set-up, you can't beat a well matched stroker motor.
Old 09-24-2005, 12:17 AM
7 Second Club
ty_ty13's Avatar
a 150 shot of juice will get you there right now..... 800$ its that easy
Old 09-24-2005, 01:42 AM
blue01ta's Avatar
I voted for the 408. I don't mind it when people know my car means business.
Old 09-24-2005, 10:51 AM
30th t/a's Avatar
my last setup w as making 455rwhp and i had 3" duals that went under the axle out the back. on a 2 hour drive to cleaveland at a steady 2000rpm it got annoying. i was wishing i had a nice quiet turbo car but then there are alot of times when having a thumpin cam. when i was just driving around my area is wasnt bad at all. just the long drives.
Old 09-24-2005, 06:12 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Do the storker thats what I am doing in my truck. You cant beat the attention you get when you pull up in a parking lot and you have a nice choppy lope. If it is too loud put a quiet exhaust on it.
Old 09-24-2005, 06:50 PM
RedWS601's Avatar
Well If I go with 408 block and h/C, should I do it all at once or do H/C 1st then the block, vice versa or all at once. Now cost is a factor because I know all at once will go like $9k including labor. But H/C will cost around $4k with labor right?
Old 09-25-2005, 01:22 AM
blue01ta's Avatar
Is your cars suspension and chassis ready to handle the kind of power you are planning on throwing at it? Also what clutch and rear end do you have? I think your numbers are easily attainable with a 408ci engine but in the end when it's all added up it will be well over $9k counting everything (H/C, 9", clutch, sfc's, cam, fuel system, suspension, etc.). If you got the money I think that is the way to go. It ain't cheap but you'll have one hell of a car when you are done. IMHO
Old 09-25-2005, 05:11 PM
1 Stout Z's Avatar
408 and spray
Old 09-25-2005, 05:22 PM
RedWS601's Avatar
yah of course it is going to be ready befor I do all this. I just need research first
Old 09-25-2005, 07:58 PM
turborail's Avatar
In my opinion it just doesn't get any better than having a killer turbocharged LS motor
