MSD Digital Install, guide me on the wiring....
Hey Guys,
I just got the MSD digital window switch yesterday, and am trying to figure out how to wire it up....
There are two wires the manual shows for hooking up to grounds...
Can anybody guide me on this?
Also, for the power wire, that it says should be switched on/off...
Thanks for your help....maybe some install photos would be helpful...
Regards,
Riggs
Regards,
Riggs
Originally Posted by riggs
Hey Guys,
I also have the TPS Switch with relay installed from NX instead of the microswitch...
Did any of you run it to the battery where it is on all the time? Or do all of you have it setup where it only comes on when you activate the nitrous?
Regards,
Riggs
Regards,
Riggs
2. You want to use a switched hot and not a constant hot wire.
3. I mounted mine on the inside of the plastic battery compartment separator of my C5 with double-sided tape. You can mount it basically anywhere as long as it's not in direct contact with a heat source, e.g., too close to the headers, etc.
4. Remember to disregard the instructions telling you to use Cylinder Mode 1 for the LS1. If you do, it won't work properly. Use the 4 cylinder mode and it will work fine.
Originally Posted by joesmith136
I have installed mine the same way. I have it in 4cy mode also but when I try to set the ON rpm it only goes to 1500?? Any Ideas??
Done with the install....thanks man, you rock!
Just gotta go get some double sided tape...
Get the 3M exterior double-sided tape. It will handle the heat better. I got mine at Wal-Mart.
Originally Posted by XTrooper
You're welcome!
Gotta do the Racetronix fuel pump install tomorrow to accomodate the wet kit..
Then to Birmingham, AL on Tuesday to get it tuned by Gomer here on the board..
I just installed a new Lingenfelter fuel pump in my 'Vette yesterday. It's working great, but now my fuel gauge isn't working so the damn float must be hung up on something!
Originally Posted by slowpoke96z28
to keep you from wasting batterry power when the ignition is off.
