Autolite plug chart??
Old 09-25-2005, 11:00 AM
fastbasser's Avatar
Default Autolite plug chart??
Anyone know where I can find a chart that can tell me which Autolite plug has the same heat range as an Autolite 103 but has a shorter reach. (or shorter threads)
Thanks.
Old 09-25-2005, 11:21 AM
DWillTA's Avatar
Not sure what you are trying to do, but here is a link to a search by specs.
http://www.autolitesparkplugs.com/se...51&action.y=13
Old 09-25-2005, 11:25 AM
DWillTA's Avatar
The plug you spec'ed is OE for the old 3.8 turbo GTA motor. I would assume that means it is a colder heat range. It is the same spec as an LS1 plug other than heat range.
