Who built your 408?
Old 09-26-2005, 03:51 PM
Kennedy98z28's Avatar
Default Who built your 408?
My factory motor went south at the track. I am looking to buy a 408 this winter. How much hp and tq are you putting down? What size cam are you running? The car is not a daily driver either. I have done a ton of searches.
Old 09-26-2005, 04:01 PM
Z'mnypit's Avatar
FFHP is building mine, obvisouly no dyno #'s yet but will soon come. The cam is a custom grind cam, 244/248 .612/.615 113lsa. Im thinking maybe around 475hp NA and 600hp or more on the jug. The CR is right at 10.7-1, & topping it off is a set of Patriot Stage III LS6 heads. If you do a search you'll find the flow #'s I posted.
Old 09-26-2005, 04:28 PM
What intake are you going to use?
Old 09-26-2005, 04:36 PM
Brandon Boomhauer's Avatar
the FAST 90/90 is the setup to run now, unless youwant to go with a carb style setup.
Zmnypit, that cam and a half decent set of heads should put you over 475 no problem.
Old 09-26-2005, 05:20 PM
Z'mnypit's Avatar
Im going to run the LS6 intake, Ill fork out the money for the fast later.
Brandon- I was try to lowball my estimates, that way it didnt seem to drastic.
Old 09-26-2005, 06:06 PM
DAPSUPRSLO's Avatar
On a motor that does not see over 7000rpm with a hydraulic cam I'd definately stay with the fast 90/90 combo. Now if you've got a solid with .700" and up lift and over 7500 rpm now we're talking carb intake
Old 09-26-2005, 08:54 PM
Shane_G's Avatar
Texas Speed.
Old 09-26-2005, 09:33 PM
Elite_Hot_Rod's Avatar
I'd build it myself and use the money I saved not having a shop assemble it for me to buy the best internals possible. Buy a new 6.0 ltr block and a Lunati Pro Billet rotating assembly and find a good machine shop to do the balancing, get a cam and a good set of heads and put it together.
Old 09-26-2005, 09:42 PM
Shorty Director
VINCE's Avatar
Check the signature..
Old 09-27-2005, 12:35 AM
Anyone else?
Old 09-27-2005, 01:26 AM
ArcticZ28's Avatar
HPE built mine. It actually just arrived. I went with them because of recommendations and talked with Erik for a while, who definitely knows his sh*t. HPE also does their own machining/building in shop, which not many others do. It's all up to you, I just felt most comfortable with them.
Old 09-27-2005, 04:13 AM
WS6 #3392's Avatar
What size of cam and which heads did you go with?
Old 09-27-2005, 09:28 AM
Restricted User
2001 Pewter WS6's Avatar
I did !!! I had a local machine shop do the short block (crank-rods-pistons) and I assembled the rest. Are you close to PA?? The shop I used was about 30 minutes from Morgantown WV.
Old 09-27-2005, 09:54 AM
Your set up is just about the same as mine, what kind of power does it make?
Old 09-27-2005, 10:01 AM
mikemodano9c's Avatar
compression seems a little low?
Old 09-27-2005, 10:15 AM
Bryan @ Speed Inc.'s Avatar
i think the fast 90/90 still outflows the carb intake. i could be wrong though. i saw some magazine build up an iron block 402 w/ a huge turbo and said they originally put the carb intake on w/ efi but got better results with the fast 90/90.
Old 09-27-2005, 10:18 AM
not if he got the 68cc chamber heads. that's where my 402 sits. 10.6-10.7
Old 09-27-2005, 10:33 AM
Z'mnypit's Avatar
My heads have 62cc chambers. The pistons are -15cc. I plan on spraying the motor & didnt want a real high CR. I know there have been guys sprying on 11.3/11.5-1 but I didnt even want to think about doing that. Not saying its a bad thing. Plus, I could always have the heads milled if I want to change it up a bit.
Old 09-27-2005, 10:46 AM
ArcticZ28's Avatar
I'm using a custom Futral 244/248 .635/.627 112 +4 cam. However, my money tree was recently cut down, so I'm using the stock 6.0 heads from my old 375 engine.
Old 09-27-2005, 10:59 AM
DAPSUPRSLO's Avatar
Wen both are ported properly there is no comparison, especially in the higher lifts areas where any lsx style manifold really limits the true potential of a head. I think you're right about the gmpp intake though, I believe the fast is superior up to about the .550" or so area, then it's all gmpp.
