What does it take to convert to a solid roller when have Gx3 cam and AFR 205 heads?
Old 09-27-2005, 12:06 PM
DRM C5's Avatar
Default What does it take to convert to a solid roller when have Gx3 cam and AFR 205 heads?
I would like to change to an aggressive solid roller set up. My engine has Gx3 cam with AFR 205 heads milled to say 57cc (it's 11.24 cr). The pistons are LS6 and notched something like 2cc with the Isky tool.
I know I will need special rockers, etc but my concern is will I need to replace the pistons or use them as is? Replacing pistons would add a lot to the cost, I think.
I appreciate everyone's input, as well as let me know if there's any other things to consider.
Paul
Old 09-27-2005, 12:17 PM
93LS1RX7's Avatar
Lifter
Rockers
Pushrods
Springs
Maybe some clearancing of the heads.
Old 09-27-2005, 12:37 PM
DONAIMIAN's Avatar
Call futural, he should be a able to take care of you and let you know everything that needs to be done.
Old 09-27-2005, 12:48 PM
Tech's Avatar
Originally Posted by 93LS1RX7
Lifter
Rockers
Pushrods
Springs
Old 09-27-2005, 02:05 PM
383ss's Avatar
do a search, plenty of threads on how to convert to solid roller.
these guys have most of it:
pushrods
springs
solid lifters
adjustable rockers
taller valve covers
longer plug wires
solid roller cam
clearance pushrod holes in heads
Old 09-27-2005, 06:42 PM
smask04C5's Avatar
MORE Money
