Trans Mount Crossmember Stud-Torque Spec?
Old 09-30-2005, 04:08 PM
lrk322's Avatar
Default Trans Mount Crossmember Stud-Torque Spec?
On the A4 trans mount there is the stud that sticks out of the bottom and attaches to the crossmember. What is the torque spec for this nut?
On JRP's torque spec list I found the following specs :
I see "trans mount to trans bolt 18 -ft pds" (thats what I set it at)
The other spec I see is "stud, auto trans case extension(Y-car) 13-16 ft pd"
Im not sure if either is the correct torque spec. Does anyone know the correct torque spec for the trans mount cross member stud?
Thanks,
Lane
Old 09-30-2005, 05:03 PM
kpowr82's Avatar
18mm trans mount nut should be tightened to 77 ft-lbs.
http://installuniversity.com/install...y_mount_m6.htm
Old 10-01-2005, 04:15 AM
lrk322's Avatar
Oy vey! Thanks for the reply. Ill have to tighten that before I drive tommorow!
