How to prelube LSX engines
Old 10-02-2005, 04:00 PM
MAC4264's Avatar
Default How to prelube LSX engines
We made this setup with parts lying around the shop. That is an old school small block oil pump that we used. We tapped the suction (pickup tube) with a pipe fitting (3/8). We also tapped the pressure side with a pipe fitting (3/8). We then used a bolt with the same thread as the oil pan, drilled it through and welded a fitting to it. The fitting going in to the block is a factory plug that has been drilled and tapped with a fiffing srewed into it.
Attached Thumbnails How to prelube LSX engines-mvc-001f.jpg   How to prelube LSX engines-untitled2.jpg   How to prelube LSX engines-mvc-003f.jpg   How to prelube LSX engines-mvc-004f.jpg   How to prelube LSX engines-mvc-006f.jpg
Old 10-02-2005, 06:02 PM
sleepersilverado's Avatar
what is that motor going in?
Old 10-02-2005, 06:35 PM
MAC4264's Avatar
93 Camaro LS1 conversion "sleeper". 402 iron block, forged rotating, ET heads (5.3 Castings)
Old 10-02-2005, 07:01 PM
nice it is a good idea
Old 10-03-2005, 03:48 PM
gearheads78's Avatar
This wouldn't be going in a colorful pace car would it?
Old 10-03-2005, 07:31 PM
LoneWolf28's Avatar
Thats a damn good idea!, i always wondered how you would do it on an lsx (are those harland sharps, if they are do they clear stock valve covers?)
