Stock trans, stock 10 bolt, 11's no problem.
It's nice having an auto! I make about 400rwhp 365rwtq with a cam only setup. I have a 4000 stall, some susspension mods and bfg drag radials. I made it into the 11s with a 1.68 60'. I still have a stock transmision(never rebuilt) and a stock ten bolt with 3.73s. I do have a shift kit and a rear end girdle. I was able to drive an hour and a half to Byron, run 11's and then drive back home with my sub bumping and air conditioning blasting. My car has about 100 pounds removed but with my stereo system I am at about full weight still.
Now I'm not saying it isn't risky, I just wanted to post to show it can be done. I see so many of those "how much can the stock tranny take?" and "Is my ten bolt going to blow up?" threads. This is just a thread for people that are scared to do anything because of all the people saying your going to break this or that. Build your car right and you can increase the chances of not breaking things. I get no wheel hop and don't just slam on the gas all the time. I also try to avoid full throttle down shifts. I'm going to keep my stock tranny and ten bolt untill they break. Next up, AFR heads and Bogarts.
You got to love it!! I do the same. Moroso is 80miles each way which I drive on my MT dr's. I plan on buying Prostars this month & will be driving them back n forth with the skinneys..
Originally Posted by OctaneZ28
I'm there with ya... not officially, but I will run 11s this month most likely.
Except no cam here, and 2.73 gears.
11s at the track, and 28MPG on the way home!
I'll be running 11's next time I got to the track, with a SS4000, and 3.73's, ET Streets and skinnies up front. Should make for a good time. I drive 2 hours to the closest track also.
Congrats on the 11s. People really do under estimate how far the stock tranny and 10 bolt can be pushed. I'll be looking for 9s with mine in a couple of weeks. And I still drive the 120 mile round trip to the track too.
Congrats!
Been there SI with bone stock tranny and 2.73's myself. I don't think you will see a whole lot of "it can't be done". More like "if you race on it long enough, the 10 bolt will break".
What I have said to anyone that asks.......you can run 11's or 10's on a 10 bolt, but have a backup plan to get home. From personal experience....it sucks to be 1 1/2 hours from home tryin to get the car back with a broken rear. It will happen, just a matter of when.
define take care of everything.. avoid full throttle downshifts, change rear gear oil, get tranny flushed often...?? i have the stock trans with 3800 stall, deep pan, 24k weight cooler, shift kit, and girdle for rear.
sry to highjack thread.
Originally Posted by ChiTownSS
I was there when he hit 11's. His car is badass!
Originally Posted by ImportPatrolWS6
I seen your run there. Good job hitting your goal, I am going to try hitting my goal, on the 22nd at 41. I have you on video making a few runs.
Import Patrol
Got a 11.14 @ 121.9 with a 1.64 60ft. Could not hook that well, but the hott track temp did not help. Figured, when I go to mayheim in morocco on the 22nd, I will hit my goal. I will check the tape again. I know I seen 2 of your runs on there. But not positive if it was of your 11sec runs, Ill check.
hey chitown ss, great job eatin that zo6 at byron
