Trouble adjusting A4 shifter after converter install
we just finished up doing a TC install into a buddies Z28, its all back togther and we started it up to top off the tranny fluid and the shifter is all out of wack. initialy on start up while in park the wheels were turning and grinding aganist the park pin(it was making a nasty clicking noise). i have messed with it alittle now trying to adjust it by removing the plastic clip and sliding the cable around forward/back, is there a certian way to do it?
we have park and reverse, but no neutral its going P-R-OD-D-2-1-1 it feels like it has 5 forward gears. I guess its stuck between gears.
this is an '02 Z28, stock 4l60e with stock shifter and a 4,000 fuddle converter.
any help is appreciated, Thanks alot
Originally Posted by CAT3
Are you sure you have it bolted to the right trans pan bolts? If not, then you wont get it right. There is no reason to have to adjust the cable from a TC Swap.
