Would you use this cam-pics inside
Old 10-21-2005, 08:45 AM
eb02z06's Avatar
Default Would you use this cam-pics inside
This cam was pulled out of a car recently-had a slight marking on one of the lobes-doesn't look like a gouge or anyhting but if your rub your fingernail over it you can feel it. What do you all think-can it be reused?
Old 10-21-2005, 09:12 AM
SUTTERERMAN85's Avatar
i would prob run it if it doesnt feel bad if you run your finger around it like the way it spins. what did the lifter look like on that lobe?
Old 10-21-2005, 09:14 AM
777's Avatar
I guess my reply didn't work, I would use it. It doesn't look that bad and cams wear anyhow. I would expect something like that if I bought a used cam.
Old 10-21-2005, 09:25 AM
dug
dug's Avatar
I wouldnt use it. Something is messed up. It could trash the motor.
Old 10-21-2005, 09:50 AM
eb02z06's Avatar
The motor it was pulled out of had no issues. BUT the heads never came off the car so we don't know what the lifter looked like-this was just pulled out and another cam was put in. It doesn't look like gouging -there is no rough edge-almost looks like it was made that way-could maybe some dirt have got caught between the lifter and the lobe? Well if can last 5000 miles I may just throw it in.
Old 10-21-2005, 10:02 AM
11SECSS's Avatar
I would use it after taking some type of polishing cloth to it just be safe the same thing machine shops do for cranks when it doesn't need turning.
Old 10-21-2005, 10:09 AM
mr2guru's Avatar
Looks fine...especially if you can't feel the mark....
Old 10-21-2005, 10:13 AM
dug
dug's Avatar
Yeah its tough to say from pic over the internet. I always play it safe when it comes to internals.
Old 10-21-2005, 12:39 PM
Brandon Boomhauer's Avatar
I wouldn't use it if you could feel any marks.
that could eat a lifter and end up completley trashing the cam, etc...
Old 10-21-2005, 01:06 PM
MAXIMO's Avatar
Yeah If you can feel the mark It should be good. I had a trashed cam and you would not like the way the marks felt. There was a machine shop that fixed my old cam for 40 bucks.
Old 10-21-2005, 04:14 PM
Keenov's Avatar
That looks like normal cam wear. As long as you don't feel much friction you should be fine.
Old 10-21-2005, 06:12 PM
Grimes's Avatar
I would not use it if you can feel the mark. Why spend all that time to put something back in that may jeopardize the entire engine?
