stereo help
Ungrounded Moderator
Yes, it will plug right in although the automatic volume feature won't work because of the lack of a VSS wire in the 94 radio harness. You might have to use the two side brackets from the original 94 radio to make the newer radio fit - they changed the bolt positions sometime in the mid-90s and I'm not sure if yours has the older or newer style.
