stereo help
Old Oct 22, 2005 | 07:22 AM
wc00ac's Avatar
Default stereo help
Will a factory stereo out of a 00 camaro fit in my 94? Will it just plug in and bolt right in?
Old Oct 24, 2005 | 08:56 AM
WhiteBird00's Avatar
Ungrounded Moderator
Yes, it will plug right in although the automatic volume feature won't work because of the lack of a VSS wire in the 94 radio harness. You might have to use the two side brackets from the original 94 radio to make the newer radio fit - they changed the bolt positions sometime in the mid-90s and I'm not sure if yours has the older or newer style.
