LS6 intake, cam, and heads.?
if i took my 00 LS1 and installed the LS6 intake,heads, and cam what kind of gains would i see. i not looking for a incredible track car just a nice street car. how close would it put me to 400hp if i have a lid,LTs,ORY,and loudmouth. and where could i find all the parts i need for the LS6 swap(intake,heads,cam)? thanks in advance. sry if its a re-post(im sure it is) im not to swift with the search button.
first thing are a you a a4 or m6 if your a m6 i would say it is possible with a good tune and if you are a a4 i would say a pulley and a good tune could do it a ported tb would not hurt either
with the time and cost of doing a head and cam swap. id say all that work for just stock heads and a stock cam is a waste of time....
there are many cams out there that will net much more power with the same character. so do some more research.....
maybe S2 LS1 heads with an 11.1 CR and a 224/224 .575/.575 116 should net around
415rwhp with an LS6 intake and a good tune! so how does 485HP sound?
good luck!
good luck!
For what you will pay I agree with the guys above. You need to just get a good set of stage 1 heads, from TEA or PRC. Cam wise, run a 224/.580 114. You will see much more power for the same dollar.
Brandon
Brandon
