What's wrong?
What's wrong?
My in-line fuse for power to my amp is popping when I try to turn it up. I haven't messed with anything in a while so I'm not sure what's going on. It's pulling alot of power at low volumes but it's not that loud. Is my amp or my speaker fried? I've got a Kenwood excelon 600 RMS and one Kicker Comp VR 12'' 400 RMS and gain on the amp is about halve way. All the wires are in the right spot. Please Help.
Don't keep popping fuses. Find what is wrong or risk frying something.
Check all your wiring for any shorts... even a single strand grounding out... the entire speaker wire paths for shorts or insulation tears... starting with any speakers that play quiet or not at all at low volumes.
If you still can't find anything I would unhook all the drivers, then swap around until you find the one causing the fuse to blow.
I didn't keep replacing the fuse. Just one time. I've only got one speaker so it's kinda hard to trouble shoot. I checked the speaker wire but it's kinda dark maybe I missed something.
a speark wire wouldnt blow the fuse, it would only put the amp in protect (unless it is shitty amp)
you need to check over your power wire, make sure there are no cracks or any strands exposed. you should also check over your ground
If the wires "look" ok Id get a multimeter on it and set it to continuancy, have the negative terminal set to a ground on the car just to doulbe check. Touch the positive terminal to the power wire. If theres a reading you should check/replace that wire. Otherwise, are you sure that fuse youre using is rated high enough?
I'm using the correct fuse. There's no continuaty from power to ground. The fuse didn't pop at low volumes but it was pulling alot more power than it normally does (There's a current meter on the amp). Voice coils are wired up correct (dual voice coil speaker), so it's not bad wiring putting a big load on the amp. Had that experience a couple years ago lol. Also when that happened the speaker was playing very loud at low volumes. This time it was quieter than it should have been, especialy with the kinda current reading I had. I can only think that it may be an internal problem with the amp or something fried in the speaker causing it to pull more power than it should. Thanks for the input so far. Are there any other suggestions with this new info.
The amp has a cooling fan and it was working. Either way though it was only on for a minute before it popped. The temp guage on the amp was showing 90* F. Any other thoughts?
