Thinner head gaskets?
Old 10-26-2005, 05:14 PM
52172's Avatar
Default Thinner head gaskets?
Would it be worth it to replace my stock gm head gaskets with some .045 cometitcs? I think it would be worth it if I picked up 10 rwhp? What do you all think? MOds in sig.
Old 10-26-2005, 05:22 PM
jhong321's Avatar
if you have the stock gaskets at .051 and change to .045 you will get your cr up .005 ie 10.1-1 to 10.2-1 you will pick up maybe 5 rwtq but i don't think any hp. i don't think it's worth pulling off your heads to do that unless you have to pull them already. if so you can go to a .041 or even a .030 to gain a little more.
Old 10-26-2005, 05:31 PM
Beast96Z's Avatar
You'd have to really like working on your car to change the gaskets for a half point of compession.
Old 10-26-2005, 05:35 PM
ArcticZ28's Avatar
Make sure your PtoV clearance doesn't get too close.
jhong321's Avatar
sorry i was wrong it's only .001 ie 10.1-1 to 10.2-1 with a gasket from .0051 to .0045
Old 10-26-2005, 07:10 PM
John_D.'s Avatar
The improvement in quench area is probably worth some too, over and above the change in compression ratio. I don't know how much improvement though. I'd be interested to hear a number on that...
