Oil Pan help!!!
Old 10-31-2005, 08:18 PM
00Z28Cammy's Avatar
Default Oil Pan help!!!
hey sup, I just wanted to know if there is a way to remove the oil pan because mine is leaking. I heard from my buddy who works at a shop that you have to lift the engine up to get to it? I don't wanna have to take it to the dealer because he said you need a special lift to do it HELP!! I'm still paying fer my car so any suggestions will help thanks I hope I'm not in the
Old 10-31-2005, 09:45 PM
quiksilver9531's Avatar
well you can drop the pan like a half an inch or so, I thought correct me if im wrong but can't you replace the gasket with just dropping the pan a half an inch or so
Old 10-31-2005, 11:20 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
It would be pretty time consuming I am sure, but technically if you can jack up the motor and remove the K-member you should be able to get it out. It will take some encouragement but can be done.
Old 11-01-2005, 08:00 AM
King James's Avatar
https://ls1tech.com/forums/showthrea...&highlight=oil
