Repin Diagram!!
Old 11-05-2005, 01:47 PM
boostedtransam's Avatar
Default Repin Diagram!!
Can someone post up a Diagram or step by step directions on how to repin a 98 pcm to a 99-02 pcm? I have a 01 pcm and a 01 guage cluster already...
Old 11-07-2005, 10:44 AM
RedBaron's Avatar
To The Top
Old 11-07-2005, 10:55 AM
Dave F's Avatar
98' Trans Am PCM
REd connector
Pin
Wire Color
Circuit No.
Function
1-2
Not Used
3
WHT
1310
EVAP Canister Vent Solenoid Valve Control
4
BRN/WHT
633
Camshaft Position Sensor Signal
5-6
Not Used
7
YEL
400
VSS Signal High
8
Not Used
9
PNK/BLK
1746
Injector #3 Control
10
Not Used
11
DK BLU
229
VTD Fuel Enable
12
LT BLU/BLK
844
Injector #4 Control
13
RED/WHT
2122
Injector #2 Control
14
DK GRN
59
A/C Status
15
BLK/WHT
845
Injector #5 Control
16-17
Not Used
18
YEL/BLK
846
Injector #6 Control
19-20
Not Used
21
PPL
719
IAT Sensor Ground
22
DK BLU
1225
Transmission Range Signal B
23
LT GRN/BLK
1745
Injector #2 Control
24
BLK/WHT
1704
Sensor Ground Jumper
25
PNK
1224
Transmission Range Signal A
26
Not Used
27
RED/BLK
877
Injector #7 Control
28-29
Not Used
30
GRY/BLK
1687
Spark Retard Signal
31
DK BLU/WHT
878
Injector #8 Control
32
ORN/BLK
434
PNP Switch Signal
33
BLK
1744
Injector #1 Control
34
GRY or WHT
587 or 687
Skip Shift Solenoid (M/T) or 3-2 Shift Solenoid (A/T)
35
LT GRN
1222
1-2 Shift Solenoid
36
DK/BLU
1936
Fuel Gauge Output Control
37
BRN/WHT
419
MIL Control
38
Not Used
39
DK GRN/WHT
459
A/C Clutch Relay Control
40
WHT or YEL/BLK
375 or 1223
Skip Shift Lamp Control (M/T) or 2-3 Shift Solenoid (A/T)
41
BRN/WHT
1173
Low Oil Level Indicator Lamp Control
42
LT GRN
1652
Reverse Inhibit Solenoid Control
43
DK/GRN
335
Cooling Fan Relay #1 Control
44
YEL
573
Crankshaft Position Sensor Signal Input
45
DK GRN/WHT
428
EVAP Canister Purge Valve Control
46
Not Used
47
DK GRN/WHT
762
A/C Request Signal
48
YEL
492
MAF Signal
49
PPL
2121
Ignition #1 Control
50-51
Not Used
52
PPL/WHT
2128
Ignition #8 Control
53
RED
2127
Ignition #7 Control
54
LT BLU/WHT
2126
Ignition #6 Control
55
DK GRN/WHT
817
VSS Output Signal
56
DK GRN
2125
Ignition #5 Control
57
DK GRN/WHT
2124
Ignition #4 Control
58
LT BLU
2123
Ignition #3 Control
59
BRN/WHT
2130
Ignition Control Reference Low Bank 2
60
BRN
2129
Ignition Control Reference Low Bank 1
61
RED
1226
Transmission Range Signal C
62
BLK
552
EGR Pintle Position Ground
63
BLK
407
A/C Refrigerant Pressure Sensor Ground
64-70
Not Used
71
PPL
401
VSS Signal Low
72
BLK
451
PCM Ground
73-74
Not Used
75
GRY
720
Left and Right Fuel Tank Level Sensor Ground
76
BLK
451
PCM Ground
77
PPL
420
TCC/Brake Switch Signal
78-80
Not Used
blue Connector
Pin
Wire Color
Circuit No.
Function
1
TAN
1671
HO2S Signal Low Bank 2 Sensor 2
2
TAN/WHT
1669
HO2S Signal Low Bank 1 Sensor 2
3
TAN
800
Serial Data (UART)
4
RED
631
Camshaft Position Sensor B+ Supply
5
TAN
1667
HO2S Signal Low Bank 2 Sensor 1
6
TAN/WHT
1653
HO2S Signal Low Bank 1 Sensor 1
7
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
8
TAN
472
IAT Sensor Signal
9
BRN
1456
EGR Pintle Position Sensor Signal
10
PPL
30
Fuel Level Sensor Signal
11
Not Used
12
DK BLU
417
TP Sensor Signal
13
YEL/BLK
1227
Transmission Fluid Temperature Sensor Signal
14
ORN/BLK
1057
Transmission Fluid Temperature Sensor Ground
15-18
Not Used
19
PNK
439
PCM Ignition 1 Feed
20
ORN
340
PCM Battery Feed
21
BLK
451
PCM Ground
22
YEL/BLK
1868
Crankshaft Position Sensor Ground
23
BLK
452
TP Sensor Ground
24
BLK/WHT
1704
25
BRN
718
ECT Sensor Ground
26
ORN/BLK
469
MAP Sensor Ground
27
Not Used
28
DK BLU
473
Engine Cooling Fan Relay #2 and #3 Control
29
Not Used
30
BRN
436
AIR Pump Relay Control
31
PPL
421
AIR Solenoid Relay Control
32
TAN/BLK
422
TCC Enable Solenoid
33
BRN
418
TCC (PWM) Solenoid Valve Control
34
GRY
435
EGR Valve Ground
35
WHT
121
Engine Speed (Tach) Output Signal
36
LT BLU/WHT
1229
Transmission Fluid Pressure Control Solenoid Control Low
37
DK GRN/WHT
465
Fuel Pump Relay Control
38
LT BLU
697
EGR Valve Control Circuit
39
RED/BLK
1228
Transmission Fluid Pressure Control Solenoid Control High
40
Not Used
41
PPL
1670
HO2S Signal High Bank 2 Sensor 2
42
PPL/WHT
1668
HO2S Signal High Bank 1 Sensor 2
43
GRY
596
TP Sensor 5V Reference
44-45
Not Used
46
PPL
1666
HO2S Signal High Bank 2 Sensor 1
47
PPL/WHT
1665
HO2S Signal High Bank 1 Sensor 1
48
LT GRN
432
MAP Sensor Signal
49
YEL
410
ECT Sensor Signal
50-51
Not Used
52
DK GRN
890
Fuel Tank Pressure Sensor Signal
53
Not Used
54
LT GRN/BLK
444
IAC Coil B Low
55
LT BLU/BLK
1748
IAC Coil A Low
56
LT BLU/WHT
1747
IAC Coil A High
57
LT GRN/WHT
1749
IAC Coil B High
58
PPL
1807
Serial Data (Class 2)
59
Not Used
60
BLK
451
PCM Ground
61
ORN
340
PCM Battery Feed
62
LT GRN
1867
Crankshaft Position Sensor B+ Supply
63
Not Used
64
GRY
416
MAP Sensor 5.0 Volt Reference
65
GRY
705
5V Reference
66
GRY
474
A/C Refrigerant Pressure Sensor 5.0 Volt Reference
67
GRY
598
5V Reference
68
LT BLU
1876
Knock Sensor (KS) Rear
69
DK BLU
496
Knock Sensor (KS) Front
70
PNK/BLK
632
Camshaft Position Sensor Ground
71-75
Not Used
76
BRN
1174
Oil Level Sensor Signal
77-80
Not Used
Old 11-07-2005, 10:56 AM
Dave F's Avatar
2001 PCM
Red
Pin
Wire Color
Circuit No.
Function
1
BLK
451
Ground
2
BRN
418
TCC Solenoid - Output - PWM
3
Not Used
4
PNK/BLK
429
Air Injection Reaction Solenoid Relay - Coil - Control
5
Not Used
6
RED/BLK
1228
PC Solenoid Valve High Control (Sol.A)
7
Not Used
8
LT BLU/WHT
1229
PC Solenoid Valve Low Control (Sol.A)
9
DK GRN/WHT
465
Fuel Pump Relay Control [Primary]
10
WHT
121
Engine Speed Signal
11-12
Not Used
13
WHT
85
Cruise Control Engage Signal
14
RED/BLK
380
15
RED
225
Generator Turn ON Signal
16
Not Used
17
DK GRN/WHT
762
A/C Request Signal
18
DK GRN
59
A/C Compressor Clutch Supply Voltage
19
Not Used
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22-23
Not Used
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/WHT
2124
IC 4 Control
30
DK BLU
229
Fuel Enable Control
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK BLU
473
High Speed Cooling Fan Relay Control
34
DK GRN/WHT
428
EVAP Canister Purge Solenoid Control
35
Not Used
36
BRN
436
37
DK GRN
83
Cruise Control Inhibit Signal
38
Not Used
39
RED
631
12 Volt Reference
40
BLK
451
Ground
41
Not Used
42
TAN/BLK
422
TCC Solenoid Valve Control
43
DK GRN/WHT
459
44
LT GRN
1652
Reverse Lock Out Solenoid Control
45
WHT
1310
EVAP Canister Vent Solenoid Control
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
2 - 3 Shift Solenoid Valve Control
48
LT GRN
1222
1 - 2 Shift Solenoid Valve Control
49
Not Used
50
DK GRN/WHT
817
VSS Signal
51
YEL/BLK
1227
TFT Sensor Signal
52
Not Used
53
GRA/BLK
1687
Ignition Retard Signal
54
PPL
1589
55-56
Not Used
57
PPL
719
Low Reference
58-59
Not Used
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
Not Used
63
PNK
1224
Transmission Fluid Pressure Switch Signal A
64
DK GRN
890
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High Control
77
LT GRN/BLK
444
IAC Coil B Low Control
78
LT BLU/BLK
1748
IAC Coil A Low Control
79
LT BLU/WHT
1747
IAC Coil A High Control
80
Not Used
Blue
Pin
Wire Color
Circuit No.
Function
1
BLK
451
PCM Ground
2
LT GRN
1867
12 Volt Reference
3
PNK/BLK
1746
Fuel Injector 3 Control
4
LT GRN/BLK
1745
Fuel Injector 2 Control
5-7
Not Used
8
GRA
596
5 Volt Reference
9-10
Not Used
11
LT BLU
1876
KS [2] Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13-16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
340
Battery Positive Voltage
21
YEL/BLK
1868
Low Reference
22
Not Used
23
GRA
720
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [Bank 2 Sensor 2]
26
TAN
1667
HO2S Low Signal [Bank 2 Sensor 1]
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [Bank 1 Sensor X]
29
TAN/WHT
1653
HO2S Low Signal [Bank 1 Sensor 1]
30-31
Not Used
32
GRY
48
CPP Switch Signal
33
PPL
420
TCC Brake Switch Signal
34
ORN/BLK
434
Neutral Safety Switch Signal
35
Not Used
36
BLK
1744
Fuel Injector 1 Control
37
YEL/BLK
846
Fuel Injector 6 Control
38-39
Not Used
40
BLK
451
Ground
41
Not Used
42
DK GRN
335
Low Speed Cooling Fan Relay Control
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (A/C Refrigerant Pressure Sensor)
46
GRA
474
5 Volt Reference (Fuel Tank Pressure Sensor)
47
Not Used
48
GRA
416
5 Volt Reference (MAP Sensor)
49-50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
407
Low Referecne (Transmission Temperature Sensor)
54
BLK
407
Low Reference (MAP Sensor Ground)
55
Not Used
56
Not Used
57
ORN
340
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
Not Used
60
BLK
452
Low Reference
61
PNK/BLK
632
Low Reference (Camshaft Position Sensor)
62-64
Not Used
65
PPL
1670
HO2S High Signal [Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [Bank 1 Sensor X]
69
PPL/WHT
1665
HO2S High Signal [Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71-72
Not Used
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
Not Used
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
GRA or WHT
587 or 687
Skip Shift Solenoid Control (M/T) or 3-2 Shift Solenoid Control (A/T)
80
BLK
407
Low Reference
Old 11-07-2005, 10:57 AM
Dave F's Avatar
Good luck, God Speed, May the force be with you. I don't envy your endeavor!
Old 11-07-2005, 01:41 PM
JimMueller's Avatar
Why does red 13 & red 23 have the same description, yet different circuits in the 1998 list?
Old 11-07-2005, 02:18 PM
Dave F's Avatar
I just copy/pasted these from the service manuals, I didn't program the cars. Sorry, I've done all I can do.
Old 11-07-2005, 09:13 PM
JimMueller's Avatar
Yes, I understand you didn't wire the car. I'm only inquiring because the information at this site doesn't match what you posted. I'm not saying the other site is correct, only that the task is already difficult enough when you have the correct information in front of you
Old 11-08-2005, 07:03 AM
Dave F's Avatar
I'm wondering if 13 should be "ignition 2 control", not injection? The circuit number resembles ignition more than injector??!!
I check the manuals for both Pontiac and Chevrolet, just in case, and they are both listed as I posted, however, I agree it does look incorrect.
Just for a backup, I check the Corvette manual, and it also lists #13 and #23 the same. I think #13 should be ignition.
Dave
Quick Reply: Repin Diagram!!
