m6 problem
m6 problem
Tranny making alot of noise, still shifts fine just lot of noise when shifting and almost sound like the shifter is rattling when crusing. any thoughts on what it could be?
pull the console, check every bolt, go underneath and do the same, odds are its not an internal trans problem, unless you havnt had fluid in it, or someone did a bad job rebuilding it
