04 z06 clutch
Old 11-08-2005, 10:15 PM
Lostpatrolman's Avatar
Default 04 z06 clutch
Will the z06 clutch be good enough for a stock engine with a 150 shot of nitrous? My clutch is shot and I dont want to spend big bucks on another one that might not last very long or give me problems. I would like to stick with something that has good durability and has proven itself. So do you guys think the z06 clutch is good enough, or do I need to go aftermarket? If I need aftermarket, what clutch do you guys recommend. The engine is stock, but I plan on spraying a 150 shot. Also, is it neccessary that I turn the flywheel? Does anyone have a good diy site for how to replace the clutch. Thank you.
Old 11-09-2005, 02:36 AM
SIC LSX's Avatar
i was looking into the same settup! but everyone told me not to get the z06 clutch. Im going with spec stage 2 kit with billet steel flywheel.
Old 11-09-2005, 06:35 AM
wicked weasel's Avatar
People are having good results with the new LS7 clutch. Figure it can handle the new C6 Z06 450rwhp so it can handle your 150 shot. It is relatively cheap and comes balanced from the factory.
Old 11-09-2005, 02:36 PM
SIC LSX's Avatar
what would i need to get the ls7 clutch kit?????? where do i find it?
Old 11-09-2005, 02:46 PM
TAF Motorsports's Avatar
here's a link
https://ls1tech.com/forums/showthrea...8&page=1&pp=20
flywheel (LS2/LS7- GM part # 12571611) and the pressure plate/disc kit (LS7 - GM part # 24233650)
you have to run the ls2 flywheel
Old 11-09-2005, 05:30 PM
SIC LSX's Avatar
Originally Posted by tom97ss
here's a link
so thats all i need to put on my 99 z28??? slave???
