Timing and N02
Old 11-10-2005, 01:55 AM
ALPINE's Avatar
Default Timing and N02
Can someone explain to me how I user/install a timing tricker? My Z06 is tuned for the juice, so it runs rich as hell n/a. My buddy told me I could set something up to be able to switch the advance easily between n/a and N02 runs.
-JC
Old 11-10-2005, 07:23 AM
Matt@HSW's Avatar
Do you mean the LS1 Timing Tuner? If so, it won't control your A/F, but yes, it will control the amount of timing that you run. Depending on how your N2O kit is installed you might/might not have to do a little re-wiring. The Timing Tuner will then activate your nitrous kit, and when doing so it will pull the amount of timing that you set it to. It also can advance your timing at part throttle and wot and includes a window switch and delay timer. More info:
Link to LS1 Timing Tuner
Matt
-JC
Old 11-10-2005, 11:31 PM
ALPINE's Avatar
Thats the money shot, thanks!
-JC
Old 11-11-2005, 10:07 AM
Caribe's Avatar
He might also be talking about putting a resistor to make the IAT detect a hotter temp thus pulling timing. Here is the thread and diagram:
https://ls1tech.com/forums/showthrea...&highlight=BMN
Old 11-11-2005, 03:58 PM
terry s's Avatar
Can anyone tell me where the AIT is located on a 2002 Z06
Thanks
Old 11-13-2005, 11:43 PM
Nitro Dave's Nitrous Outlet's Avatar
Terry,
WE have had real good luck with the timming tuner. We sell alot of them. I have not tried the resistor mod.
Dave
