Solid motor mounts Part 2
As a few of you have seen i made some solid motor mounts for my car and a buddies. well another friend of mine wanted some too. As seeing as how i am now addicted to reducing my race weight i decided to make these out of aluminum.
The first pic is of the steel ones i made a while bacl and the second is of the aluminum ones i made last night. i didn't that the aluminum ones looked a little weaker (especialy it being aluminum) so i took one of the sets and welded asome reinforcement plates on the side. after i did that i then didn't like how bulky they looked so i left one set just like they were. i figure i'll put the weaker (lighter ) set in my car and the other in his. So if mine break i can just weld them back up. Wouldn't wanna put something faulty in someone elses car. I'll get a pic of the "reinforced" mounts here in a little bit.
Originally Posted by ROCNDAV
wanna help me make some pedestals?
I was thinking of making some out of aluminum, or lighter gauge steel. The stockers weigh a ton!
i made these cause no one makes colid motor mountsd for the k members that have the bottom section of the mount built into it.
Originally Posted by flyinZ
What are the pros/cons, by running solid motor mounts like those, than running a plate setup? (motor plate)
Simplicity: you don't have to change anything about your motor set up just swap out the mounts and go. plates take alot of fabrication.
Restricted User
Originally Posted by SUX2BU
nope.
con- engine blocks HAVE cracked when you make enough power
