Drag Racing Tech
Solid motor mounts Part 2
Old Nov 11, 2005 | 06:11 PM
SUX2BU's Avatar
Default Solid motor mounts Part 2
As a few of you have seen i made some solid motor mounts for my car and a buddies. well another friend of mine wanted some too. As seeing as how i am now addicted to reducing my race weight i decided to make these out of aluminum.
The first pic is of the steel ones i made a while bacl and the second is of the aluminum ones i made last night. i didn't that the aluminum ones looked a little weaker (especialy it being aluminum) so i took one of the sets and welded asome reinforcement plates on the side. after i did that i then didn't like how bulky they looked so i left one set just like they were. i figure i'll put the weaker (lighter ) set in my car and the other in his. So if mine break i can just weld them back up. Wouldn't wanna put something faulty in someone elses car. I'll get a pic of the "reinforced" mounts here in a little bit.
Attached Thumbnails Solid motor mounts Part 2-11464535941_3300.jpg   Solid motor mounts Part 2-96012715909_3300.jpg
Old Nov 11, 2005 | 06:20 PM
gearheads78's Avatar
Looks good but I agree. I would gusset the alum. ones a good bit.
Old Nov 11, 2005 | 06:53 PM
ROCNDAV's Avatar
wanna help me make some pedestals?
I was thinking of making some out of aluminum, or lighter gauge steel. The stockers weigh a ton!
Old Nov 11, 2005 | 07:51 PM
SUX2BU's Avatar
kinda shitty pics cause its dark out side.
Attached Thumbnails Solid motor mounts Part 2-96018927109_3300.jpg   Solid motor mounts Part 2-96018861701_3300.jpg
Old Nov 11, 2005 | 07:54 PM
SUX2BU's Avatar
just buy the solid motor mounts that everyone sells that way you eliminate the heave stock pedastool and the heavy motor mounts.
i made these cause no one makes colid motor mountsd for the k members that have the bottom section of the mount built into it.
Old Nov 12, 2005 | 06:06 AM
chpmnsws6's Avatar
haven't a few people ripped a hole in the side of there block with solid motor mounts?
Old Nov 13, 2005 | 12:58 PM
SUX2BU's Avatar
nope.
Old Nov 13, 2005 | 01:52 PM
chpmnsws6's Avatar
hmmmmmm...... those things are sweet to. go launch like hell on the aluminum ones...... i wanna see how they do before i beg ya to make me a set
Old Nov 13, 2005 | 04:15 PM
flyinZ's Avatar
What are the pros/cons, by running solid motor mounts like those, than running a plate setup? (motor plate)
Old Nov 14, 2005 | 12:41 AM
SUX2BU's Avatar
Well for me plates are too "race car"ish.
Simplicity: you don't have to change anything about your motor set up just swap out the mounts and go. plates take alot of fabrication.
Old Nov 14, 2005 | 02:44 AM
CAT3's Avatar
Restricted User
Originally Posted by SUX2BU
nope.
Actually yes, a few ppl back in the day did when using Madman, Spohn or BMR, cant recall exactly which one, but I researched this before last year while deployed and remember reading about it.
Old Nov 14, 2005 | 05:02 PM
chpmnsws6's Avatar
pro- less stuff in the engine bay. the motor plate is a PITA to work around
con- engine blocks HAVE cracked when you make enough power
