Spray & 3600 stall & 3.73's? Please Help
Would I have to shift into OD before the traps if I put in my 3.73's and added spray? Should I just sell the gears *still new in box* and just leave the 3.23's in the rear if I go with the spray? I was going to get the gears put in this coming monday but got to ride in a sprayed car today and was like . If I do both is there anyway to know about what rpm I would be turning at the line? Im thinking if I go with the juice i'd get a wet kit and stay around a 100 shot if that helps.
It would also depend on what size tire you are going to run. I run a 28" tall tire with 4.10's, 3600 stall and a 100 shot and I cross the line at about 6200. I have yet to try the 150 shot.
Jody J.
Jody J.
Lets say the 100 shot adds 10mph to your trap speed, so you would be trapping around 118mph. With a 26" tire and 3.73 gears you should trap about 5700 rpm, assuming you have a m6. If you have an a4 you should allow for about a 5-10% slippage.
Thanks for the help guys im just trying to get this sorted out before the gears go in.
I spray 150, with a 3600 stall, lgx3 Cam, stock heads and stock rear end, 3.23. I personally wouldn't go over a 3.42 gear if you are going to spray 150. And believe me, you will spray 150 eventually. It is to tempting
Originally Posted by DevonsZ
So I should be ok then?
There is no question about this period.
Originally Posted by white2001s10
No don't use the 3.73's. You'll go faster on the bottle with the 3.23 gears.
