Needed: Best and strongest valve springs
Old 11-12-2005, 12:37 AM
supersix's Avatar
Default Needed: Best and strongest valve springs
I need to know which valve springs are the best and strongest on the market. The lift on the cam is over .620 on both sides. This is for a stock LS1 head with stock valves. I also need to know what shims, seats, and retainers to use. I am thinking titanium retainers....but don't know if they are required or what to go with....I also need to know where to get all of these parts. thanks in advance.
Brett
Old 11-12-2005, 08:51 AM
777's Avatar
Not necassarily the best or the strongest, but all that you should need. The PRC duals which come with hardened seats, ti retainers, springs rated for .660 lift, valve seals, they are around $250
Old 11-12-2005, 09:44 AM
TAQuickness's Avatar
supersix - you should read the cam guide sticky. towards the bottom is a lot of information about setting up a valve train to support your cam.
Old 11-12-2005, 09:54 AM
PREDATOR-Z's Avatar
There is PRC "platinum" duals for .670 lifts
PRC gold for .660 lifts
Patriot gold for .650 lifts
Old 11-12-2005, 10:02 AM
777's Avatar
I thought platinum was for .660 lift...?
Old 11-12-2005, 10:34 AM
PREDATOR-Z's Avatar
https://ls1tech.com/forums/showthrea...light=platinum
PRC gold at .660, I edited my post
