problem with clutch
problem with clutch
i did my engine swap and also installed a new clutch. i connected the master to the slave with the engine/trans out of the car and bled it some to get it close. and installed everything. when it was all in i knew it still needed to be bled so we started bleeding . my friend didnt watch the resevoir close enough and it ran dry and now the pedal just drops to the floor when you start to depress it. it also makes a sound like its sucking air. anyone have any tips?
yep, you must have scored the seal in the master and its leaking, cant remember if there's a rubber cover and that may be filled w/fluid also, your gonna need a new master, unless that one's rebuildable, not sure on that though..... you might find a used one, alot of people have upgraded master's when changing clutches and have the stocker's collecting dust somewhere...
