305 hop ups
305 hop ups
hey guys... SLIGHTLY bt as a whole it is
got an 89 TPI 305....
magnaflow exhuast, K&N filtercharged, ACCEL ignition system, B&M shift kit (and possibly tranny rebuilt at one time and diff. ratio put in...doest feel like stock ratio at all...TOO fast) that is the extent that i see has been done to my car...
well...im going to redo almost EVERYthing
starting on exhuast so it sounds better
hooker 1 5/8" long tube headers
my catalac converter though... i am quite ignorant... whats a good company to go with...and model??
from there i am getting meineke to build a custom 3" exhuast for me... and put either woody wood peckers or glass pax...
then since its gunna sound better and keep me happy for a while...
imana save for heads and cam... and do pulleys too
question though on cam... my engine has a FRESH tune up...last owner SHOWED the receipt to me...
and the engine lobes like it has a bigger cam.... but not incredibly much...... my 1st firebird... it revs kinda semi quick and idles around 1200rpm then drops to about 800 to 700 rpm when its warmed up and sitting there
no funky noises... still runs great and everything
normal for an 89 tpi?? or may i possibly have a mild cam upgrade?? or some other type of problem
anyways... after that im going to put a better intake... and some type of holley TB... not that far yet though
THEN SOMEwhere in between all of that im getting it repainted b/c he black is fading.... and my parents are going to pay for half of it for either my birthday/xmas or early graduation present...
and the deal is that if i make all A's.... ther gunna go outrageous on my grad. present...... so... i've made plans
EDIT
talked ot my dad
he said it MIGHT be a bad MAF sensor going bad... makes sense.... i'll change that out when i go get all my fluids changed and change my thermostat
EDIT
talked ot my dad
The worst thing u can do is put some dam glasspacks on there! If ur gonna go that route get some bullets, essentially the same thing but the sound and flow alot better!
I would just buy a cheap 3 inch cat and gut the sob out! But thats up to you if ur not gonna gut it i would buy a good name brand one, like magnaflow i hear lots of good stuff about them!
http://www.car-sound.com/catalog/universal/mirror.aspx
lurch
lurch
DynoMax cats are supposed to be good to and they flow well enough that you really don't make any gains by gutting them.
If they are gonna go crazy for your grad present and you plan to keep the car stay with the mods you got and buy either a 350 or 383 short block from GM and then just upgrade the runners and manifold base of the TPI and maybe port the throttle body then you'll have som fun.
o0o
how is it on emissions though...
my dads a FREAK about it
apparently emissions is hard to pass in IL
i like the sound of glass packs and their cheap
i was thinking...
i like the delta 40's and when u mentioned it.. i have heard them... and they KICK ***!!
but looks like they only come single inlet single outlet
im not sure i have enough ROOM to run two pipes down... so i'd have to have a split after the cat....
i was thinking the same firefighter...or just getting them to buy me a brand new GTo or Firebird and slam on some bolt ons
im gunna consider that and call meineke about it
i was thinking...
