Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
piston notching flycutting tool
Old 11-18-2005, 08:18 AM
GuitsBoy's Avatar
Default piston notching flycutting tool
Hey guys, I think i may want to flycut my pistons. I have a junk head that I can hack apart. Im thinking about buying two $10 BBC valves and grinding notches around them to make a makeshift isky type tool. Ill probably grind a hex into the valvestem tip so I can stick a socket on it. Ill probably cut up the head so there's only one cylinder and 4 bolt holes on it, and ill have to reem out the valveguides to fit the 3/8 stem. Anybody see any problem doing it like this?
Ive got to do 2 or 3 cars, but not at the same time, so i cant rent. And my budget does not allow to buy the isky tool.
Old 11-19-2005, 07:35 AM
JRick212's Avatar
i highly doubt that your makeshift tool is going to do anything in the way of removing material or doing it cleanly
Old 11-19-2005, 08:16 AM
GuitsBoy's Avatar
Why not? Its little different than re-grinding the flutes on carbide endmills at my dads machine shop, and Ive suvessfully done that plenty of times. Besides, its aluminum. Rub a Q-Tip against it long enogh and you can cut a valve relief.
Quick Reply: piston notching flycutting tool
