katech rod bolts in car???
Old 11-19-2005, 08:05 AM
NX_CaGEdApE00's Avatar
Default katech rod bolts in car???
Is the rumor true that using katech rod bolts it is safe to replace rod bolts with motor still in car??? If so what is the proper installation technique in doing so...????
Thanks
Old 11-19-2005, 08:21 AM
rollinna65's Avatar
I've heard you can do it with the motor in the car. Of course you've got to drop the oil pan which means dropping the k-member unless you've got an aftermarket tubular piece. This is something I've been looking into a lot lately. Its like really cheap insuance on my bottom end but I can't find the motivation to do it. That's why I now shift around 63-6400rpms instead of 66-6800.
Old 11-19-2005, 08:28 AM
i hear ya... might as well get a light weight k-member when doing them....
thanks
dave
rollinna65's Avatar
Hey it says in your sig that you ran that time (no clutch), do you mean clutchless shifting or you had a bad clutch. If you meant clutchless shifting, how'd you do it? What were your shift points and stuff? I'm too scared to try.
Old 11-19-2005, 08:30 AM
sorry it means bad clutch.......
Old 11-19-2005, 08:33 AM
rollinna65's Avatar
Damn, you got me all excited. Oh well, its probably better that I don't try it.
