u-joint needed
u-joint needed
i just got a ford 9 inch with a 1330 yoke, i would like to keep this yoke. i am running a aluminum driveshaft with the stock u joints. i need to know which u joint i would need to go from the stock drive shaft to the 1330 yoke. i know the driveshaft needs the lock rings on the inside and i think the 1330 yoke needs the inside lock rings too because the 1330 has tabs on the outside of the yoke. thanks for your help
