ported tb
ported tb
wasent sure where to post this, g&m would be my second guess.
has anyone ported thier on tb? i was thinking about doing it myself. we have all the tools and everything, but we've never done it or seen it done before. is it sensitive? meaing can you screw it up very easily?
i've done mine... you can screw it up easily around the throttle blade... there's a little ridge right behind the throttle blade when it's closed - i grinded that off - then the idle was WAAAYYY too high becuase of all the air getting around the blade... a simple fix was JB welded the little hole in the throttle blade and that fixed the problem. as far as the intake side of the throttle body, just try and make everything as smooth as possible.
