Max effort 346
Max effort 346
Hey guys after blowing up my motor I have decided to build a max effort stock cube motor to race in some events, but still be streetable. I just wanted to see what some of you think about a good rotating assembly and valvetrain I should use, also any tricks or tips that can be done to extract that last ounce of power. I am going with Cartek's 3x LS6 heads and cam, since I still have these from my old motor. I also just ordered the FAST 90mm (which will be port matched to the heads) and Nick Williams TB and have SVO 30lb/hr injectors with a racetronix plug n play pump. Any help or suggestions would be greatly appreciated. Thanks
LS1TECH Sponsor
Heads, Cam and Compression are what will make HP. So for you it will be compression as the other 2 are fixed. I am looking at the same thisn myself. Availability of race fuel will determine what I do.
