Will a Trans Go shift kit aleviate a p1870 code?
Does anyone know if a Trans Go shift Kit would help a p1870 code?
My mods are in my sig a TCI ssf 3500 stall, transcooler and tune in regards to transmission work. Do you guys think that a Shift Kit would help?
Thank You
Sincerely
Robert
Thank You
Sincerely
Robert
That code sets when the converter stops locking (it only sets when the converter is commanded to lock up) meaning a loose converter won't set it. An inoperative converter clutch will.
As far as the TransGo kit fixing it, that depends on why its setting. If its setting because the valvebody is worn out, then yes, it will. If its setting because the solenoid is bad or the converter is bad, then that won't fix it.
