1.8rr on a stock ls1 good idea? and gains?
Old 12-03-2005, 01:28 AM
ZeroTraction's Avatar
Default 1.8rr on a stock ls1 good idea? and gains?
well i see a popular performance is doin some 1.8rr arms would this mod do much for a stock 01 ss m6? if so what kind of gains would i see? whats the best brand for the buck/performance rr to run? thanks
Old 12-03-2005, 01:38 AM
jrp
SN95 Director
jrp's Avatar
hp/$ ratio is low. i'd opt for a larger cam and or a combination of both (cam and rockers), something along the lines of the VHP accelerated rockers and cams or another low lift variant cam.
Old 12-03-2005, 09:29 PM
4mula's Avatar
youll get about 10 h.p from 1.85 rockers.
i ditched the rockers for a cam.
Old 12-03-2005, 10:24 PM
mrr23's Avatar
my gains using the vinci/crane 1.8 accelerated lift rocker kit on stock 99 ls1 cam. stock tune as well.
dyno 9 before
dyno 11 500 miles later
dyno 14 10 months later
Old 12-04-2005, 09:51 AM
Vetteguy2's Avatar
I went to the Yella Terra 1.8 shaft mounted roller rockers $500. at TR. No mods needed to the rocker covers needed. With Comp. 918 springs & Chromoly push rods. Picked up about 20 hp & a lot of TQ.
Old 12-05-2005, 12:07 AM
BlackHawk T/A's Avatar
All you are doing is changing your valve lift and a small amount of duration. You may as well change your cam instead.
"Mod cheap, and you'll end up modding twice"
Quick Reply: 1.8rr on a stock ls1 good idea? and gains?
