Moser 9" for 3rd Gen Camaro in 4th Gen ?
I have a 99 camaro SS with a 4 channel rear end. I found a 9" Moser rear for a 3rd
gen camaro. I think the 3rd gen will bolt right it be it's 2" shorter on each side. I will
also lose my ABS and TC but what else will I have to do to make it work?
Originally Posted by 86irocz
The 82-92 camaro's are narrower and you will have to buy new axles to keep the ABS. What ends are on the housing? Not sure if you can reuse your existing brakes or not.
It has a drum brake setup on the 3rd gen rear but I was going to change them to my disc brake on my 4th gen rear.
