STENOD Build-up Pt 4
The project is coming along pretty fast now..... i just need kevin to send me some higher rez pics
Dual -8an out of the sump into a Earls Y-Block
-10an feed, -8an return
A brand new sumped stock 98 Tank.... my old one was rusty as hell....
Aeromotive Proseries Fuel Pump
FMIC Finished and Mounted
Rossler Powerglide
My Motor and Trans are in For Good.
Its geting closer every day..... im excited
Kyle
Rossler Powerglide
Kyle
what kind of hp #'s are you wanting to get out of your set up? I always like seeing your progress pics keep em coming. Also when are you guys expecting everything to be buttoned up?
Im not really worried about HP #'s im more concerned with ET at this point i want low 9's...... 900rwhp would be nice... we will see if it happens with the 76mm wheel that in there now.... if not i have a few tricks up my sleeve.
Thanks guys
Kyle
Very nice,looks better everytime i see more pics.my fav 1 is the pic from behind the car with the hatch up so u can see the full cage hey Kyle can u pm those fittings that i need that u said u would for my fuel setup when u get a few minutes to spare.looks
Thanks man... i loved the cage..... and it looks even better in person....
i PMed you.
Kyle
Originally Posted by Nine Ball
Why didn't you just go with one larger line off the sump instead of the Y?
Nice pics, I wish Stenod was located in TX
Tony,
The outlets on the sump are 3/8 NPT so a -8an. we could of opted for the 1/2 npt sump kit but we wanted to use the 2 -8an outlets to feed the 1 -10 i knew we were going to use as a feed. In the beginning that is what i had on my old fuel tank (before we found out it hand a crap ton of rust in it) so all th fittings were already ordered for what i had already. Hope that helps.
V8_DSM_V8again,
Those are one off headers for my car made by STENOD Performance.
Thanks Guys im hoping to have more pics today and higher rez ones also.
Kyle
Well they look nice..
I will likely need to make my own... I cant LOW front or rear mount them on the truck. Its going to be tight with both a big coil over and bypass shock up close to the engine ..
What l need to be almost like having your headers but swapped left to right and a slip fit turbo collector on the end.. Put them in the upper front area... Either that go to the rear corners of the engine bay... That would be better for exhaust and turbo intake mounting (fording type snorkel) .. Incedentaly I'm going air to water... I'd kill a FMIC so fast.... I'll put the exchanger either in front of the radiator or in the bed cage somewhere..
I'll have to finish the chasis, install the engine and trans.. Get that all right then design my headers..
Your project looks awesome so far...
