STENOD Build-up Pt 4
Old Dec 11, 2005 | 03:33 PM
NA$TY-TA's Avatar
Default STENOD Build-up Pt 4
The project is coming along pretty fast now..... i just need kevin to send me some higher rez pics
Dual -8an out of the sump into a Earls Y-Block
-10an feed, -8an return
A brand new sumped stock 98 Tank.... my old one was rusty as hell....
Aeromotive Proseries Fuel Pump
FMIC Finished and Mounted
Rossler Powerglide
My Motor and Trans are in For Good.
Its geting closer every day..... im excited
Kyle
Old Dec 11, 2005 | 03:38 PM
LTLHOMER's Avatar
Looking good man as always...can't wait to see it start making noise.
Old Dec 11, 2005 | 04:00 PM
oodahss's Avatar
what kind of hp #'s are you wanting to get out of your set up? I always like seeing your progress pics keep em coming. Also when are you guys expecting everything to be buttoned up?
Old Dec 11, 2005 | 04:15 PM
NA$TY-TA's Avatar
Im not really worried about HP #'s im more concerned with ET at this point i want low 9's...... 900rwhp would be nice... we will see if it happens with the 76mm wheel that in there now.... if not i have a few tricks up my sleeve.
Thanks guys
Kyle
Old Dec 11, 2005 | 05:03 PM
ls1-ss's Avatar
Now that is SEXY!! I can't wait to see how it runs on the dyno and the track.
Old Dec 11, 2005 | 05:10 PM
JMBLOWNWS6's Avatar
Ok I know you have more PICS. LOL Show them
Old Dec 11, 2005 | 05:24 PM
NA$TY-TA's Avatar
I will have more on Monday Prob..... it was after 5pm when i called on Fri and everyone was gone except Joe (it was payday too) Ill get some more dont worry
Kyle
Old Dec 11, 2005 | 05:53 PM
White.Lightning's Avatar
Lookin good as always. Startup is in the near future. I (we all) can't wait
Andy
Old Dec 11, 2005 | 07:51 PM
Tiago's Avatar
looking good, getting antsy yet?
Old Dec 11, 2005 | 08:34 PM
NA$TY-TA's Avatar
hell yeah i am..............
Old Dec 11, 2005 | 09:42 PM
Slowhawk's Avatar
LS1Tech Sponsor
Car looks great
Old Dec 11, 2005 | 09:46 PM
ddnspider's Avatar
Very nice,looks better everytime i see more pics.my fav 1 is the pic from behind the car with the hatch up so u can see the full cage hey Kyle can u pm those fittings that i need that u said u would for my fuel setup when u get a few minutes to spare.looks
Old Dec 12, 2005 | 09:46 AM
NA$TY-TA's Avatar
Thanks man... i loved the cage..... and it looks even better in person....
i PMed you.
Kyle
Old Dec 12, 2005 | 09:48 AM
V8_DSM_V8again's Avatar
What headers are those?
Old Dec 12, 2005 | 09:55 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Why didn't you just go with one larger line off the sump instead of the Y?
Nice pics, I wish Stenod was located in TX
Old Dec 12, 2005 | 11:03 AM
NA$TY-TA's Avatar
Tony,
The outlets on the sump are 3/8 NPT so a -8an. we could of opted for the 1/2 npt sump kit but we wanted to use the 2 -8an outlets to feed the 1 -10 i knew we were going to use as a feed. In the beginning that is what i had on my old fuel tank (before we found out it hand a crap ton of rust in it) so all th fittings were already ordered for what i had already. Hope that helps.
V8_DSM_V8again,
Those are one off headers for my car made by STENOD Performance.
Thanks Guys im hoping to have more pics today and higher rez ones also.
Kyle
Old Dec 12, 2005 | 11:36 AM
Well they look nice..
I will likely need to make my own... I cant LOW front or rear mount them on the truck. Its going to be tight with both a big coil over and bypass shock up close to the engine ..
What l need to be almost like having your headers but swapped left to right and a slip fit turbo collector on the end.. Put them in the upper front area... Either that go to the rear corners of the engine bay... That would be better for exhaust and turbo intake mounting (fording type snorkel) .. Incedentaly I'm going air to water... I'd kill a FMIC so fast.... I'll put the exchanger either in front of the radiator or in the bed cage somewhere..
I'll have to finish the chasis, install the engine and trans.. Get that all right then design my headers..
Your project looks awesome so far...
Old Dec 12, 2005 | 07:40 PM
00Formula's Avatar
Looks awesome Kyle.....looking forward to seeing some dyno numbers when its all done.
Old Dec 12, 2005 | 09:27 PM
NA$TY-TA's Avatar
Ill be glad just to have it back.....
Kyle
Old Dec 12, 2005 | 09:45 PM
fash00's Avatar
More Pics
