Does a 4l60e have a shifter linkage adjustment???
My shifter dosent go all the way into 1st gear... actually it dosent click into 1st.... So I figure the cable needs adjustment... I just had a new 4l60e installed...and im guessing the cable adjustment was over looked....
not really.. it pretty much just bolts in place and afaik there is no place to adjust anything.
I would check to see if everything was tightened down like the bolt that holds the cable to the lever and the cable to the trans pan. There may be a slight amount of movement available on the trans pan bracket.
