Best plug for magnacharged 383 with meth
I would say that the TR6's are a pretty good plug for your application...the reason for running the cooler plug is so that the actual plug itself doesn't heat up and have a dieseling effect from being so hot...these are great for the forced induction applications such as what you are running and help if you're dumping quite a bit of boost...From the thousands of articles in every thing that I have read I came across why the factory used such hot plugs and it was not for performance...It was because the cats need to be hot to work properly so they used a hotter plug to get it there quicker so that they could pass emissions...Those type plugs are not intended for extreme performance applications...A good example of this would be the platinum plug that comes in LS1 from the factory...This is to last 100k miles but we all know to junk those things because they tend to spark in the manner that I have highlighted before...
Thanks dawg.
Location: Tinker till it blows, then back it off a notch, maybe!!
1 Post
Originally Posted by V-seriesTech
Best plug for afr'd 383 with a magnacharger.
Anyone had good experience?
TR6?
Methanol injection will be used.
Thanks
TR6?
Thanks
