No MAF, 4150 intake with a 4 barrel Throttle Body.
I currently use HP Tuners to tune my car and have had success with it thus far. I got rid of the LS6 Intake and ported tb I had, and I now have a Edelbrock Victor Jr intake and I am gonna be using a Accufab 4150 1200 cfm tb. My question is, without switching to Big Stuff 3, would I still be able to keep the factory pcm and run the Accufab tb and victor jr without any tuning related problems?
YES! Although we use an Accufab Mustang 90mm TB, I did talk to Accufab about the 4-BBL TB and they use GM connectors when possible, or Ford connectors. Just splice the "new" connectors to the harness and you will be good to go. No need to go to an aftermarket ECU.
6600 rpm clutch dump of death Administrator
Yup, you can tune it in SD. The only issue will be ensuring the voltage input from the TPS is right, and any other non Gm sensors you might use. But, yes it can be done.
