Removing T-Top center channel to paint?
Has anyone taken theres off. The manual shows to remove 8 screws then just take off. Mine appears to be glued or at least sealant also and I am just wondering how hard it is to remove. TIA
Originally Posted by camarossman88
what are you painting it with cause mine is durning like a gases blue look to it?
Thanks
James
I am just going to have it painted black at my buddys body shop. Paint it just like any other body panel. Yes I know what your talking about mine is doing the same thing. It is black but has a blueish swirl look to similar to what gas looks like on top of water.
I used Vinyl on my car to fix the faded look. I used Carbon fibre vinyl on it and I think that it looks awesome.I took a large piece and just layed it over the whole surface. If you use high quality vinyl it should last around 5 years or longer if you clear over it, Then in 5 years peel it off and re-apply new vinyl. Took me about 10 mins to do it and it looks killer...
maybe by wet sanding it but it wont looks as nice as it will once you have a body shop paint it....im glad someone posted about this cause i went the other day to a friends shop to see how much it would be and he said it would be $20....i'll prolly do it after christmas
