Need Some Help After New 12-bolt Install
RECENTLY HAD A BRAND NEW MOSER 12-BOLT W/4:10'S "PROFESSIONALLY INSTALLED" IN A 2001 CAMARO SS M6. RUNS AND DRIVES GREAT, BUT AT VERY LOW SPEEDS <10 M.P.H WHEN COMING TO A STOP, SLOWLEY TAKING OFF, AND WHEN MAKING TURNS ITS MAKING A POPPING NOISE THAT I CAN FEEL THROUGH THE SHIFTER. ONLY OCCURS AFTER DRIVING FOR A WHILE AT HIGH SPEEDS. ALMOST FEELS LIKE ITS COMING FROM THE DRIVESHAFT. DID I GET A JACKED UP REAR END? BAD INSTALL? SOMETHING WITH THE TRANNY?ANY ADVISE WOULD HELP.
Originally Posted by 86irocz
Check the diameter "roll out" of both rear tires. You could be working the posi too hard and causing the clutch pack to grab at low speeds.
