sooo close, twin turbo buildup
well everything is in, everything but the crank sensor is working, im not getting an rpm reading at my computer so it wont fire, but its close...pics are on this page..
http://www.cardomain.com/ride/2108416/1
forged 355 4 bolt splayed, trick flow heads, -22cc srp pistons, mls head gaskets, twin master power t-70's, 24x12x4 fmic
no, im using a megasquirt II...plug access is very tight, but you can get to them without removing the headers, but the pass side downpipe has to be dropped to get to some of the pass plugs
Originally Posted by Assassin
is that the drain going to the bottom of the pan?, is there a reason you didnt run it gravity to a higher spot?, nice set up, that things gonna be a freakin monster
