Are LS7 heads to much for a 408?
Old 12-20-2005, 12:44 PM
snketr's Avatar
Default Are LS7 heads to much for a 408?
Are they to big for the 4.030 bore? I'm building a 408. Thanks
Old 12-20-2005, 12:52 PM
Nate_Taufer's Avatar
Yes you need a 4.06 bore minimum. Wait for the L92 heads to come out.
Nate
Old 12-20-2005, 01:06 PM
snketr's Avatar
Waht are the L92 heads? And when will they be out?
Old 12-20-2005, 01:54 PM
GPowrie's Avatar
Default ls7 small bore
we are also offering a small bore ls7 using a smaller valve and chamber, but still using a stock LS7 manifold, and stock ls7 rockers.
Old 12-20-2005, 02:00 PM
Quickin's Avatar
For a 4.100 bore are your 265 41's still going to outflow the LS7 heads?
Old 12-20-2005, 06:21 PM
Red12secZ28's Avatar
What size runner is on your small bore ls7 heads and what do they flow? Just curious.
Old 12-20-2005, 09:52 PM
Collections Hold
Cary@Perf-Induction's Avatar
Default heads
they are really neck and neck. the ls7 is a little better is some areas and the 265 in others. REmember though, the 265 has a 2.100/2.125 valve and the LS7 has a 2.200 inlet valve. On a larger race engine, they sometimes like the larger valve.
As far as flow and port volume, I should have that answered by next week, Were still programming and machining, and being that it is computer generated, kinda gotta wait til we have a finished part.
