ET Performance heads, anyone using em?
Been doing some research and ET P heads keep coming up. I understand that when using these heads you gain .150" free drop over a standard LS1 head. This means G5X3 easy and without flycutting wouldn't it!? I have tried to do a search but the search is down. Whats the story with these heads?
Rob
Rob
Collections Hold
free drop
depending on the chamber volume, it will effect the actual free drop. with a small chamber (64) cc, it has about .080- .100 more free drop than a stock style head. And yes there is a lot of people using them right now.
With a stock 346 bottom end, how big a cam can be installed using ET heads without flycutting?
What CC head should one look into if he plans on keeping a stock 346 and adding a big cam?
The wait is/was for the valves they come from venazula and that's the hold up from what i've herd i'm getting the 225's with a g5x3 no flycutting but u will need a 8" pushrod and that combo should make in the 480-490 with the right tune mods there are small cam c6 at 500 rwhpthe power comes from the 11degrees angle compared to 15 on a ls1 that's why they make power just like the ls7 that's 12 I think -Vern
