Rate my LS6 Stage-II Heads...
Stage-II ported LS6 (243) Heads (local shop)
2.02" Intake valves
1.57" Exhaust valves
Superflow SF-1020
28", 3.90 bore
Lift - Int - Exh
.200 - 141 - 114
.300 - 196 - 160
.400 - 252 - 190
.500 - 292 - 206
.600 - 319 - 215
Heads will be used to complement a Comp XE-R 224/224 .581" .581" 114LSA + 2 deg advance.
Lookin' for a little feedback on whether or not I should try and get them reworked for a bit better flow in the midlift, or if you think they'll provide some pretty darn good power as-is....
TIA!
2.02" Intake valves
Superflow SF-1020
28", 3.90 bore
Lift - Int - Exh
.200 - 141 - 114
.300 - 196 - 160
.400 - 252 - 190
.500 - 292 - 206
.600 - 319 - 215
TIA!
!LS1 11 Second Club
They look great except for .300 value. Otherwise, very healthy.
Your cam won't take advantage of the good upper lift numbers however. Get something with a tad more lift maybe, to wring it out. Also, those heads beg for a little more duration; 228-230 won't kill ya.
