Lifter orientation
Thank you!!!
Derrick
Thank you!!!
Derrick
"Now, place your lifters and lifter retainers back in place like they were when you removed them. Try to keep them oriented exactly like they were before you took them out. If you don't remember how they came out, don't worry, and just put them in however. Its not that big of a deal."
Now, next question: Why in the world wouldja use the stock (weak!) lifters on a motor that's gonna run to over 7k? Now that's begging for trouble! I have the Comp Rs and they're quiet as a mouse.
Huh? What? Half up? Half down? In ye first post you were worried about Fwd/AFT orientation. No yer talking like you put the lifters in upside down????? All the rollers better be down on the cam!
The lifter cups keep the rollers oriented correctly to the cam. No way to install the lifter 90* out of whack unless the cup is screwed up. The oil holes don't matter, front, back, makes no difference. They were in both directions from the factory on my car.
The lifter cups keep the rollers oriented correctly to the cam. No way to install the lifter 90* out of whack unless the cup is screwed up. The oil holes don't matter, front, back, makes no difference. They were in both directions from the factory on my car.Trending Topics
Well, I finally fired her up this morning. Ran like crap (computer needs to relearn everything, and I don't have a good LS1 edit program yet for this 427 setup), but she ran. But I had no oil pressure after about 10 seconds of running, so I shut her down. I thought maybe I popped the welsh plug out in the front of the block for the oil galley, but after tearing the front down, it was still nicely JB welded in place. So I put the front back together and turned her over using the starter (plugs removed) and she built up oil pressure. I guess I just had to wait another 2-3 seconds when she fired up for all the galleys to fill/pressurize. I also found a bad plug wire (must have damaged it in the tear down). So now I'm back to reassembly.
Thank you all,
Derrick
