need some compression figuring help
HI,
I have a flat top piston and 5.3 heads what kind of compression am I at?
and can I use a thicker head gasket to lower the comp some?
THanks
ed
firebird455@gmail.com
THanks
ed
With .002" piston to deck height and a .040" compressed gasket you will be around 11.1 CR. With a .050" compressed gasket you will be at 10.8 CR. Those are both with the 62cc chambers you said above.
